E46 Intermitent rough Idel and loss of power
stiovov
Hi Guys,
I have a problem that has me stumped with my 01' 325Ci. This is an intermittent problem happening mostly after the car has sit in idle for a few minutes. The car seems to begin idling very badly and a loss of power. Once this starts happening it loses power drastically and it sounds as if its Misfiring... Interesting enough is when I switch the car off then On again it runs fine for a bit the starts again. Could this be an ECU problem since disconnecting and reconnecting the battery seems to work, or what are some of your thoughts?
Just did a full service 5k Ago
Prev
Administrator
I had the same problem a while back and the mechanic sorted it out. Had to replace one of the breather pipes, I think it was near the manifold and the repair was not expensive. Hopefully yours is the same issue.
Maveric12
Yeah I been getting the same problem....mechie also mentioned someting about breather but dont kow where it was will ask him to check again. thanx
Wicked_1
According to me that "breather" will be the crank vent valve,or such,on the intake manifold,e36 one goes for R880,dunno e46 though.Also,its your crank breather,in a fancy non return valve or something.Will be close to the firewall,on the intake mani,e36`s is round
Prev
Administrator
If I recall correctly, on my E46 the mechanic charged me R175 for the part excl labour...will need to dig up the invoice to make sure.
