CreamyGoodness
hi guys,
I managed to trace a minor coolant leak - there is a water hose that attached to a connector below the expansion tank. The connection is directly above the "S" bend in the air intake snorkel, and is hidden by this bend. The pipe seemed a bit perished where it attached to some hose connector but also looked like it could do with a hose clamp as there was nothing securing the pipe.
I don't know if that's a good enough description, but can anybody identify this hose and if so, is it dealers only or can I replace with a generic automotive water hose?
It's a 30mm inner diameter and I couldn't trace where the other end went, but it looked like it was heading upwards and towards the firewall.
Unsure of which one it is on RealOEM also, so any help would be appreciated.
thanks :wave:
thanks :wave:
