Rooi_Willie
Interesting thread
opcorn:
Yuvan said:Can that Carputer handle the vibration of that beast woofer? :fencelook:
Pho3niX90 said:Yuvan said:Can that Carputer handle the vibration of that beast woofer? :fencelook:
I hope so, I was thinking of maybe replacing the HD with an SSD that doesn't have mechanics spinning, but I have seen another thread where a guy also used a lappy HD and the hard drive only died after 5 years, so will give it a test and have regular backups. At least the casing has a lot of rubber anti vibration fittings inside. But will have to test and see what happens.
Mr Occo said:Pho3niX90 said:Yuvan said:Can that Carputer handle the vibration of that beast woofer? :fencelook:
Just get the SSD.
Or go hdd but run raid 1 (mirror)
http://www.thegeekstuff.com/2010/08/raid-levels-tutorial/
Yuvan said:Can you use external drives for storage and OS? If so than i saw somewhere they have these external HDDs for rugid use, dont know how effective they are but FYI, maybe give them a lookup!!!Keep this thread updated bra, its interesting, hope all is a smooth process!! :thumbs:
Pho3niX90 said:Yuvan said:Can you use external drives for storage and OS? If so than i saw somewhere they have these external HDDs for rugid use, dont know how effective they are but FYI, maybe give them a lookup!!!Keep this thread updated bra, its interesting, hope all is a smooth process!! :thumbs:
Yes external drives can be used. Do you know who make these harddrives?
Thee board I am using has:
8 x usb 2.0 ports (2 of them are fast charging ports, will be extended to front)
2 x usb 3.0 ports
Mr Occo said:Would this not have been better? It comes in windows form as well
http://shop63.co.za/index.php?route=product/product&product_id=623
Pho3niX90 said:Mr Occo said:Would this not have been better? It comes in windows form as well
It would have been cheaper, and would have done the job. But i am abit of a computer geek, so want the ability to change what I want.
Mr Occo said:
Shiny said:Try RS components even though im not sure they have the correct size or interface
http://za.rs-online.com/web/c/optoe...-by=default&sort-order=default&view-type=List
So this didn't run out as I wanted, they don't appear to have them in stock, and I need to deposit 50% then they will order, and normal turn around time according to them is 6 Days. If I buy from ebay I will tafe about R700 and same turn around.Mr Occo said:
Pho3niX90 said:So this didn't run out as I wanted, they don't appear to have them in stock, and I need to deposit 50% then they will order, and normal turn around time according to them is 6 Days. If I buy from ebay I will tafe about R700 and same turn around.Mr Occo said:
I have found another guy advertising 7" touchscreen on olx. so sent him/her an sms now asking for availability, when that's received I can start wiring everything :joy:
