Hey Guys,
My 330i has been making allot of odd noises lately. The 1st is I noticed a ticking noise from inside the cabin, the best I can describe it, it sounds similar to the Wheel of fortune it does increase slightly with RPM.
The 2nd one I am quite concerend about is I get the thud/knock while I shift from 1st,2nd and 3r, it seems to be getting worse. I have also noticed I need to keep the clutch in for a few seconds before I can engage first, If I leave it in neutral the press the clutch and engage first It needs a bit of force to get it in(Does not grate)
3rd I get a horrible whine when I engage the AC (Was regassed a month ago and does not get used regularly)
4th I get a clunking sound from the Rear Drivers side Wheel when taking corners or under hard braking.
5th This is the latest one, I noticed today while parking my car. I think it may be a tappet noise. Sound like a sewing machine and increases with RPM and sounds like a diesel when idle.
Any Idea's? I am hoping it is not too serious. I have had the Diff bushings replaced, I still need to get the VANOS Seals and Rattle Kit. I have had the subframe inspected and there are no crack or signs of fatigue. She is currently on 128885Km's
