E46 330d 150kw price of mainetance and mods
Waseem 333i
Hey guys
I thought of letting you guys know and costing of the things I have done to my car so far and ask how much I can expect to pay for things i still need to do.
Firstly the service costed me R750 for parts. I did it myself apart for oil change. Racing snake helped me with that because i didnt have a jack.
EGR delete was already done via software by previous owner. The intake manifold is spotless clean. I've done the swirlflaps myself. Didnt cost anything because i used screws to block of the holes instead of the blanking caps.
I had an issue with the alternator regulator. Removed that without removing the alternator and replaced the brushes R20.
Low pressure power steering hose. +- R50
Aircon regas R580 The guy that did the regas is a really helpful guy. He even read the codes for me and car showed to have no errors despite me having an issue where the car wouldn't rev past 3000rpm.
The first time i did the regas we found that the heater was stuck in the open position. I took apart the heater valve and found a little blue cap that fell off. Soldered it back and valve worked again.
The car needs more work to be done but its still takes me everywhere without hassle apart from the fuel consumption. I took a 600km journey this past weekend. I was not driving with eco in mind. I still have a little diesel left in the tank. Shockingly the tank returned around 650km range. First shot i want to take is remove the DPF and fit a downpipe. Now I've got a few quotes. Power flow in edenvale said R2700+- for downpipe or R800 to remove the cat.
Currently my pockets are not running deep so what would you guys advise? Eventually i will do a performance downpipe and exhaust but only late next year.
I also need to still clean out the intercooler and service the auto box.
Nikhil
Decat or down pipe and service the auto box next, after that I will advise on the rest. :rollsmile:
Waseem 333i
Some people say downpipe R650. Is that just removing the cat and fitting a pipe? Gearbox is more priority now the downpipe. Millage is on 186k but was looking at cheap downpipe for now to save on fuel. This thing sucks about the same as 330i.
Just so you guys know what it looks like. This was shortly after i bought it.
DieselFan
It depends on the shop working on the car some will just cut a hole in the car and remove the insides. Others will cut it out and replace it will a pipe. If they're replacing it with a pipe then go for it. R650 is not bad. I paid R800
Nikhil
Thats a sweet looking ride :praise:
I'm going to suggest this in the following order
gearbox service
Inter-cooler clean
Oil breather filter change
swirl flap removal
Down pipe
Replace all the vacuum lines
drive train (diff mounts, prop carrier bearing, and guibo)
Crank damper pulley (preventative maintenance)
Cooling system
software or a chip all depends on your preference
I can also help you with some of the stuff depending on where you based:=):
A link to my thread
http://www.bmwfanatics.co.za/showthread.php?tid=47586
Andy1GP
Sounds like you have vacuum leaks. Get the 4mm vacuum hose from midas or the like, replace all of them and check how she drives. Then start working down that long list of DIY's until they're all done :)
Do the cheap fixes first and work your way up.
Waseem 333i
Thanks so much guys.
I have another thermostat housing which i still need to fit. The current one is stuck in open position so takes long to warm up. That also accounts of high consumption.
Oil breather i still need to sort out. Swirl flaps done already.
From cosmetics side i only cleaned out the lights front and back. I need to replace weather guards on both lights and the trim by the wipers and a bottom respray.
Let me gooi some pictures
Like my knob?
Thats how i found the EGR
For the heck of it, My pride and joy
