E46 320d boost problems
ydbark
Hi there. I apologise if the question has been asked before. I have not read through the other posts.
I have a 2003 E46 320d. I'm having a complete power loss.
1) i have checked all vacuum hoses
2) i have cleaned the egr valve
3) removed swirl flaps
4) done a complete service
5) checked boost pipes
6) turbo was reconed 4 months ago (car was pulling like hell)
the only thing that hasn't been done yet is a diagnostic, the local bmw mechanic can't do it because (acording to him) of a low voltage output.
I tested the battery = 12v
I tested the altenator = 14v
Please I need help.
netercol
ah thats a pity.. im in pretoria and i might have been able to help with reading error codes..
either way, doing a diagnostics scan is the recommended next step, maybe somebody closer to you can chip in and help..
ydbark
I was thinking of taking the car to BMW for the diagnostics, just to see what errors are thrown out if any. The egr valve does not move easily by hand, is that normal? There is only boost after 3000rpm. Could it be because of a sticky valve?
Pr0PheT
if u come to jhb I can do it for u for free .. I have the BMW DIS, only thing is im quite busy at work ...
ydbark
Thanks for the offer, i might just take you up on it. I don't have any wheels at the moment as I started stripping again this morning. I'm gonna fit a new egr valve and check all hoses again. I will get back to you whether i had any sucsess. thanks again!
ydbark
Finished fitting new egr, fitted new performance silicone vacuum hoses...still nothing. I still only get boost at 3000rpm.
Rian
Hi all
I have a 320d 2003 E46 , had to change engine , and now i have no boost at all , replaced with new vacuum hoses on whole vacuum system. checked actuators , even changed maf sensor from old engine, also took turbo from old engine and put it in , turbo was recon'ed by turbo exchange , and done an excellent job , and i would recommend them any time. But still absolute no power , I am out of ideas now, i have a Delphi diagnostic tool and it did not show any severe codes , and the ones that were stored was cleared , please can anyone help or give advise on what to do next
