E46 318i Hidden functions
Pho3niX90
A wile back I discovered a article relating to the hidden functions of all BMW's, can't really remember where it was, but there is one specific one I like to use alot, it's the 5.1 function (Est KM to next refuel), now my question is, how accurate can this be? I have previously driven my BMW when it said 1KM left, but yesterday I had allready driven like 300+KM and could still go about 500?, it seems alot for a 2000 318I?
Does anyone else here use those functions?
Spy007
The problem it it all depends on how you drive. If i am not mistaken it calculates on the last 10km driving style.
I avg 650km on a tank with gopher.
whattingh
the calculation is done on only the last few km's fuel consumption. Thus if you floor is from robot to robot you will see it drop quick, but then you drive like grandma for a bit and see it go up again to a point. I trust my fuel gauge and distance so far on tank much more.
andrewbuch
Instead of that "hidden" Function.. get yourself an indicator stalk with the BC button on it, get it fitted & coded & then you have OBC functions :)
Rishaan
Hey Budd... you say " hidden functions" ???? i have a 2000 model 318i ( M43 motor ). i dont think ive seen this option.... how do i get it to work ,and are ther any other hidden functions i should know about ? :ty:
Rishaan
andrewbuch said:
See here
<iframe width="425" height="349" src="
" frameborder="0" allowfullscreen></iframe>
AAAAAAW MAN..... MY INTERNET ACCESS DOES NOT GRANT THIS VIEW, ANY OTHER FORMAT YOU CAN SHOW ME ?
THANKS THOUGH
Pho3niX90
Instructions to access the hidden OBC functions:
Hold Trip Reset while turning ignition key to on position
OBC should show "Test"
Use Trip Reset to select function 19.0 that unlocks all the features
Wait for display to show "Off"
Depress Trip Reset for 1/4 second and release it
With no delay press Trip Reset several times to select one of the following function s
BMW E46 On-Board Computer (OBC) Hidden Codes
nr example description
1 Car Engine and cluster data
1.0 46nnn Chassis nr/VIN serial number (last 5 digits)
1.1 4nnn K-number
1.2 690236 Cluster Part #
1.3 045210 Coding (04)/diagnosis (52)/bus index (10)
1.4 1200 Week (12)/year of manufacture (2000)
1.5 09_160 Hardware (09) and software # (16.0) of cluster
1.6 Not used
1.7 04__44 CAN-version (04) KI-revision index (44)
2 (test) Cluster System Test - Activates the gauge drivers,
indicators and LEDs to confirm function
3 SI Data
3.0 1098 Used fuel in liters since last SI (Service Inspection)
3.1 0231 Periodic inspection days; elapsed days (since last SI)
4 Momentary Consumption
4.0 0145+ Instant fuel consumption - 0145=14.5 liters/100km
4.1 0018 Instant fuel consumption - 0018=1.8 l/Hour
5 Distance Gone Consumption
5.0 082 Average mileage; 082=8.2 liters/100km
5.1 0536 Calc. km to refuel (momentary distance to go)
6 Fuel Level sensor inputs in liters
6.0 109330+ Fuel level averaged; Left half sensor input=10.9 liters; Right sensor input=33.0 liters
6.1 0439+ Total tank level averaged; vlgs 6.0: 10.9+33.0=43.9 liters
6.2 0442+ Indicated value (44.2) and tank phase
7 Temperature and Speed
7.0 021+ Coolant/Engine temperature (2.1C)
7.1 130 Ambient/Outside temperature - chg met 5 pts. 125/130/135
7.2 + Engine speed / Current RPMs 1/min
7.3 + Vehicle speed / Current Speed in km/hour
8 Input value in HEX form
8.0 1d0+ System voltage ADC-Value Hex code
8.1 26C33C+ ADC Values HG left/HG right
8.2 0000 ADC Value brake degradation sensor (000=o.k.)
8.3 18C ADC Value outside temperature
9 Battery
9.0 140 Battery Voltage - 140 = UB 14.0v
9.1 242013+?
9.2 074_78+?
9.3 0011+?
10 Not used
11 Not used
12 Not used
13 GonG Gong Test
14 Not used
15 Status cluster I/O-ports (bit codes) 0=low; 1=high
1st-belt contact, seat belt fastened=0; 2) ignition lock contact, key inserted=0; 3) door contact, door open=0; 4) clock button pressed=0; 5) SI reset=0, for reset=0; 6) EGS transmission failure=0
Status Digital Outputs (bits) 0=inactive, 1=active
1) Gong output; 2) Brake warning lamp; 3) Low fuel warning lamp; 4) EGA lamp; 5) seat belt lamp; 6) manipulation dot
16 Not used
17 Not used
18 Not used
19 Lock Status; unlocks functions in range 3-18
19.0 L-On/L-Off Unlock: press button when "L-Off"
20 Not used
21 Software Reset; reset OBC settings
00 End of test
Could you explain more about this?? And where do I get it and for how much?:ty:
andrewbuch
Basically you go to a scrap yard.. Buy a indicator stalk with the BC button on it..
Then you disconnect your battery for 30 minutes.. then remove your airbag, and then indicator stalk & replace it with the new one..
then you fit all together again..
then you get someone to code the car so it knows the OBC function should be accessible
Pho3niX90
The indicator stalk, is it from another model BMW (specific one) or any? Does the function display auto on the dash? or should i still go into test mode and enable it?
