andrewbuch
Christiaan-SA said:Hello Guys
"Car hesitates under acceleration, in all gears, up to 2000 rpm, beyond which it is as smooth. Cold start is also horrendous."
I am new to the Forum to ask some advice on the following. I have a 2005 E46 318i Individual with 102k km on the clock.
Cold start is very bad, as if it is only firing on 2 of the 4 cylinders almost. After the 3rd or so try normally get it started, once I can get rev's to 2000rmp it idles fine. Car is on 102k km and problem has become much worse, when it was in 95k range had in in twice, no errors found and valves set - somewhat better for a week or so, then issue again as be4. I'm about to go on an expensive sensor replacement spree as technicians can't seem to pinpoint.
Further info
The car hesitates under acceleration, in all gears, up to 2000 rpm, beyond which it is as smooth as it should be right up to the red line. Between 1000-2000 rpm the car bogs and kicks when put under heavy load. If you ask for light acceleration then it is not so bad but when you ask for some grunt it just stews.
The worst it possibly behaves is when in slow moving city traffic when you would expect the engine to be at its warmest.
Anyone ever experience anything like this? Any advice would be greatly appreciated!
Kind Regards, Christiaan
I am experiencing a similar problem with a 2000 E46 318i 134000km.. Having the E36 sorted out next week then going to get them to check the e46 after that..
