freerider said:Control arm bushes
Diff mounts
Radiator expansion tank
Ricky318i said:-oil use: about 500ml per 20 000km
CARBON ATTACK said:hey guys, i have a 2005 318i, and my aircon has a mind of its own. it comes on weneva it feels like. some days it workz and some days it dosnt come on at all. does this happen to anybody else?
freerider said:Nope, I havent had any tests done, from reading up at e46fanatics I see that there are quite a lot of guys that complain about oil usage by the m54, and many that say theirs doesnt use a drop like you.
But as I say, since changing to LiquiMoly, my oil consumption is right down. I'm also changing my valve cover gasket this weekend which is currently leaking, I'm not sure how much oil is lost there though.
Ricky318i said:Firstly you need to find out if you have the N42B20 or the N46B20 motor. These are two different engines and i can only speak for the N42 which i had.
This sounds like a Electronic problem which can be solved with proper diagnostics.
Have you had your car at Auto Atlantic or similar? Have you tried Zeemax? Maybe they've encountered something similar. Get all the info before you spend money. Send me a PM and i'll give you someone's name that might help.
Christiaan-SA said:Hello Guys
"Car hesitates under acceleration, in all gears, up to 2000 rpm, beyond which it is as smooth. Cold start is also horrendous."
I am new to the Forum to ask some advice on the following. I have a 2005 E46 318i Individual with 102k km on the clock.
Cold start is very bad, as if it is only firing on 2 of the 4 cylinders almost. After the 3rd or so try normally get it started, once I can get rev's to 2000rmp it idles fine. Car is on 102k km and problem has become much worse, when it was in 95k range had in in twice, no errors found and valves set - somewhat better for a week or so, then issue again as be4. I'm about to go on an expensive sensor replacement spree as technicians can't seem to pinpoint.
Further info
The car hesitates under acceleration, in all gears, up to 2000 rpm, beyond which it is as smooth as it should be right up to the red line. Between 1000-2000 rpm the car bogs and kicks when put under heavy load. If you ask for light acceleration then it is not so bad but when you ask for some grunt it just stews.
The worst it possibly behaves is when in slow moving city traffic when you would expect the engine to be at its warmest.
Anyone ever experience anything like this? Any advice would be greatly appreciated!
Kind Regards, Christiaan
semaj said:Maintenence:
-Front control arm bushings = R2200
freerider said:semaj said:Maintenence:
Wow, I got my polyurethane ones for R115 each, and it cost me R580 to have them fitted. (the R580 included wheel alignment)
-Airbag light reset(low voltage from standing) = R200
Ricky318i said:freerider said:semaj said:Maintenence:
Please let me know where you got those Polyurethane ones. Mine was done about two years ago, still fine, but just in case. Also, i know someone who might need them.
Did they tell you that the airbag light will illuminate when the voltage drops below a certain volts? I have noticed this in a friend's vehicle last week. Also after a flat battery.
RR Booi said:Christiaan-SA said:Hello Guys
Further info
Have exactly the same issue as well. If get more info will let you know.
Thanks to all the other guys for your input.
