e39 reverse lights switch......
Roundal
My reverse lights have stopped working. They would work on and off, but now don't work at all.
I suspect the switch. Is it located on the gearbox or near the shifter under the panel? Remember mine is manual.
zaleonardz
It is indeed on the gearbox, you can test the switch by unplugging it, and using a continuity tester on it. If car is in reverse, you should have a closed circuit.. If you do, then its something else.
