Truvalu
rick540 said:Three wires is good ole narrowband sensors.
Two sensors before and after cat is OBDII system. (Your car has either three or four sensors depending on whether it has one or two cats).
As far as the before cat sensors are concerned
Bank I is cylinders 1-3
Bank II is cylinders 4-6
Carefull here! An O2 sensor error does not specifically mean the sensor is stuffed, it means the sensor is giving an out of specification fuel/air reading either because it is stuffed or something else in the injection system is not working correctly.
O2 sensor errors can be caused by:
Intake air leaks
Stuck injectors
Engine temparature sensor faults
A blocked catalytic converter
Bad or leaking fuel pressure regulator
A faulty engine ECU
A blocked air filter
A blocked fuel filter
and finally a fsked sensor
____________________________________
O2 sensor test
Remove the offending sensor/s
Get a multimeter, set it on volts so it can read between 0 and 1 V
White wires are the heater, ignore these.
Black wire is O2 output, connect to +ve of multimeter
Grey wire is ground, connect to -ve of multimeter
Stick a pin in the wires if you have to to get a connection.
Under no circumstances short the sensor or apply a voltage to it, both will kill it. Do NOT try to measure it's resistance Only measure it's voltage
Get a blowtorch
Gently heat the sensor tip (The part that's usually inside the exhaust) with the blowtorch till cherry red and watch the voltage.
Diagnose sensor
No voltage or very low voltages or a very slow response (voltage change) if you remove the flame indicate it's stuffed
- voltages mean it's contaminated with silicone or antifreeze
A maximum of 0.9V with the blowtorch on the sensor tip dropping quick if you remove the torch means the sensor is working 100%
A maximum voltage of 0.7 to 0.9 is the useable range, any maximum below this, replace sensor
When the engine is running the voltage it wants is 0.45 (stochiometric lambda is 14.7 air to 1 part fuel, the perfect mix to burn everything) and it swings up and down just around this point.
Less than 0.45 is mixture too lean
More than 0.45 is mixture too rich
Narrow band sensors are available in 1,2,3 and 4 wire versions heated and non heated and floating ground or grounded, 12watt or 19 watt heaters.
As long as you get the same type, you can fit any damn sensor from any car as a substitute and it will work just fine. I'll risk being flamed and go as far as to say, you can chuck any damn narrow band sensor in there, even a 1 wire one and it will at least work.
You do not have to spend like 10K at the dealers to sort this O2 sensor issue out, it is possible to make a plan
Hope this helps
Thanks a lot Rick!
This is scary for me!
This is the only vehicle I have and I have serious budget restraints.
I don't have a garage or somewere proper to get under the car and just for now maybe just disconnect the sensor for now.... I think the one nearest to the engine? Could that make a difference or is it bad for her? Should I try and have the cats removed.... quoted R 300 at SupaQuick Paarl, but on my own risk???????
I recently added fuelsystem cleaner to my tank, could that be what is making it smoking very, very slightly whilst idling at length.
The person who did the diagnostic said his system could not "get into" the sensor to read it.
I asked him if he could set the auto door lock function and he started searching all over the program.... that is when I realized that he has little experience with BMW's he tells me lots of things he has done wit VW's and Opels on his machine....
I am seriously sad, but thankfull for your help so far.
I think I need some attention to the front suspension to. Some creaking noises when i turn the steering at parking speed.
