If the car is still relatively level, just dampers need to be replaced. If you want to spend some money, go for Bilstein or Eibach, but IMO the stock suspension is great. If you are on a tight budget, you can get shocks fitted at a place like quickfit. You should be able to do the front for less than R3000. Mine was R2500 a year or so ago. They are probably gabriel, but work great. Don't know about rears, but let us know. I am about to replace my thrust arm bushes, and have found some that are apparently better than the OEM ones, but should be cheaper... Will let you know when I have sourced them locally.
