E39 530D 2002 Starting problem
RobinBez
Hi Guys
Starting problem with our E39 530D 2002
We have checked the following :
-Cam and crank sensors
-fuel lines and Pump
-Battery
The BMW also then only starts up when Quick start has been sprayed into the inlet manifold
What your opinions ?
RobinBez
yush1 said:
Glowplugs?
Yeah glowplugs are fine ...
Codes that was given previously :
= Rail pressure monitoring on engine start
=Exhaust- gas re-circulation or exhaust re-circulation controller
husaindindar
Sounds more fuel delivery related.
Is there fuel on the rails? Injectors working fine?
Don't over do the quick start thingy. I've heard is burns off the oil layer on the bore causing wear...
