+1StK said:The main problem with putting in an M3 engine is EWS...So you would need the Key/Barrel/EWS module/ECU as well...The best option would be to get an M3 donor car ie one thats been in a prang then you can use all the bits you would need for the conversion :thumbsup:
WerriesM5 said:It is posible to make the DME work in your 328i, it will have EWSII then the M3 DME also must be from a EWSII car. You just need to recode the DME to work on a new ISN code from the EWS.
I am doing it on my 340i conversion, making a EWSII 740ia DME work with my EWSII from my 328i and factory keys.
WerriesM5 said:I havent done much on the 340i conversion lately, I'll onley be back home in December..
I have already got a post '97 325tds steering rack in the car. I am having a custom oil pump made out of billet aliminium to relocate the pump to fit the engine in the correct position and with a custom made sump. Alpina used a custom oil pump infront of the steering rack, but I want the pump behind the cross member (where it belongs on a e36) Then I can mount the engine lower down and as far back as possible.
