BillyBob
Okay, so....
New shocks and springs in - car's easier to get in and out of, way more comfortable to drive, the knocking in the right front is gone, and the car feels fantastic at low speeds.
The shimmy over 80 km/h is still there, but MUCH less pronounced, and now only seems to be coming from the front of the car, especially when braking - pull it onto the wheel alignment machine, feel the right front wheel, and there's a knock - control arm balljoint is stuffed, and seems to be missing the retention bracket in the bottom. *facepalm*
So, while the LCA bushings seem to be okay, I'm guessing balljoint replacement is in order - unless someone could recommend a full aftermarket control arm assembly with balljoint?
BMW wants R650 just for the bloody retention bracket..
Also, the right front wheel is tucked in under the car - it sits probably 20 mm further inwards than the left... WTF? Could anyone shed some light as to why? Control arm doesn't look to be bent - but will have it checked and replaced if it is - I'm clueless as to suspension though, so what else determines the offset of the hub and wheel assembly?
Thanks in advance!
Thanks in advance!
