Thunder
nazzeem said:moranor@axis said:in your position what I would do is this:
Fit H&R front springs for now to sort out the gap and make the car look good
Save up for Koni STR.T fronts (your shocks will need replacing sooner or later anyway and STR.T are not that much more than a cheap replacement)
Fit Rear STR.T once front is sorted
after that if the balance of the car is good leave as is if the balance is out then look at getting H&R rear springs
Thanks. This sounds like a good plan.
I agree with moranor here. I have the combo he is referring to in my E36 318I and it rides like a dream. While they check your shocks also check your shock mounts at the same time so you know to perhaps budget for them in the future as well.
Sent from my GT-I9300 using Tapatalk
