E36 328i Knocking noise
LPM320
Hi Guys.
My car has started making a knocking noise from the rear part of the drivetrain. It goes away when you press the clutch, and occurs mostly at low revs, irrespective of whether you are accelerating or rolling in gear. Wierd thing is it starts to happen only after the car has been driven for a while.
Any ideas?
LPM320
you guys think there is any possibilty of it being one of the driveshafts? How would you check if it is the driveshaft?
whats the frequency? if it sounds like its going the same speed as the wheels it should be after the diff if not look at the diff or before...
snaix
Banned
My E46 was making a funky knocking sound at low revs too, mainly in lower gears. Took it to mechanic and he just tightened up the prop. No problems since.
Nikhil
I got the same problem So i went and ordered this kit
E36 Rear Suspension Mount Package
Part #: E36REARBUSHINGS
Turner Motorsport has focused on the needs of weary E36 owners by coming up with this upgraded bushing package for the rear suspension/subframe. With the bushings being so critical in the E36, keeping up with the maintenance of these parts will do wonders for the ride/handling. This package covers all of the bushings in the rear suspension – it’s everything in one box! Buy as a package and save $$.
Package includes:
rear subframe mounts (stock M3 bushings - upgrade for non-M cars)
rear trailing arm bushings with TMS limiters
inner camber arm bushings
Outer camber arm bushings
inner upper spring arm bushings
Outer upper spring arm bushings
differential mounts (TMS solid type, safe for street use)
rear shock mounts with TMS reinforcments
Wherever possible we upgraded each of these bushings to provide better handling or make them last longer. These bushings are all designed for street use but most of them are upgrades of the original bushings. We also sell solid Delrin or aluminum bushings but they should only be used for track cars and only as a kit with other solid mounts. Individual items available of course, click here.
Shipping Dimensions: 12 X 12 X 12
Shipping Weight: 18.00
Regular Price: $809.46 (USD)
On Sale For: $759.46 (USD)
I hope it stops the problem 0_o
