Major
I bought this car at around 188k, and did an oil change in September around 194k to Castrol 20W50 dino oil (which was probably not a good idea). If I remember correctly this noise started shortly thereafter, but then again the car was still relatively new to me and I might have just been more paranoid about engine noises after an oil change. I've since, in March at 202k, done another oil change to Mobil1 0W40 synthetic, and the noise has continued.
It's worse when the car is warmed up, especially at low RPM's, or just after starting it. I notice it driving next to walls, at traffic lights, etc. It's a clear, almost lashing-type ticking noise, but rises and drops a little bit slower than engine RPM changes (the noise will "hang" while the revs drop). What are the usual culprits here? Engine has no other issues apart from a rich, off-throttle popping which you can sort of hear in the video below. You can more clearly hear the noise on cold start-up, this time it wasn't as bad as usual once it was warm. Maybe it's worse when driven hard, this was a relaxed drive.
[video=youtube]
[video=youtube]
