E36 318is hard clutch
Hi Fantatics, what would a make clutch hard when pushing it in and also make the engagement point is low. Some help would be appreciated.
Nikhil
Replace clutch master cylinder and clutch hose, bleed the system and top up with some fresh fluid and it will be as good as new :thumbs:
I might do that just spare some cash for now and hopefully all will be good,if not then the 3.5k+ bill will be in my future:cry:
Leekay
danieljames said:
The Diabolical said:
Mr.k said:
its a common sign that your clutch is worn
Even if the gear changes are smooth ,no grinding and it doesn't slip?
My apologies
sent from... a phone
I had the same issue of a hard clutch, what i did was just to change a cluctch plater and i went smooth and soft again,yet looking at the old one it looked way still fine i also dont know what causds it to be hard
