E34 Touring build
Uber Soldat
Tis been a hot minute since I last posted here.
Onto the fun stuff.
Have wanted one for quite some time. Only 48 in total made it down here (24 Manuals and 24 Automatics - all 525i). They're pretty darn scarce.
So...found the below. Parking by touch didn't work that day.
After taking the front bits off...yeah, quite bad.
Got some quotes to do the repair, good thing I was sitting down.
Around a month later, while talking to the previous owner of the first touring, he mentioned that he knew of another project car...
Well yeah.
Stripped out the interior to find that 80% of the wiring harness had been cut out.
Took out the entire harness from the first touring and put it in this one.
Yeah...needing some throwing star covers.
Dyed the carpeting and seats black.
The plan was to swap in a V8. Enter 1 x parts car.
Transferring some brackets from the donor 540. The previous owner had swapped in an M5 drivetrain.
Wiring harness is mostly in:
Uber Soldat
Thank you kind sirs.
Installed the fuel return line. V8 cars have this running down the right hand side whereas the inline 6 cars, the line runs down the left hand side. Strangely enough, the attachment points for the brackets that hold the line in place were already on the touring.
The rear seat had some pretty rubbish leather. Managed to get some grey leather off a seat in Latvia, swapped it and dyed it black. (Thanks Tom and Benji :) )
Had to cut some holes in order to run the V8 fuel and brake lines. The inline 6 cars have the lines run on the inside of the left fender rail. If they stayed there with the V8 in place...much boiling will take place. The V8 cars have them running on the outside and through the body as seen below:
Removed the autofail and engine from the donor car.
The rear cross member needs to be swapped as well. The V8 gearbox would interfere with the inline 6 crossmember.
Touring:
Donor:
Sanded the engine bay and prepped it for paint.
Rear seats looking pretty damn good.
  • Like
Reactions: AKA
KPM3_30
Moderator
Welcome back bud!
Awesome to see some E34 content, especially in wagon guise.. Looking forward to the updates!
P.S - Let's see more of the E32 and E36 :smilebounce:
