E30 injector advise...???
Tigger
Hi there guys.
I need new injectors for my 318i E30 M40, and I would like to get some of your advise on the matter...:)
Most injector systems can just have the injectors swapped with little bigger one's, then get the timing done again, and bob's your uncle...
Does anyone know if I will be able to do that with my M40? And maybe what other injector I can use?
Thx:thumbsup:
Major
Don't do it. Bigger injectors don't necessarily improve your performance one iddy biddy bit. And your timing is controlled by a distributor, so unless you have a whole new EMS lined up you won't change that either.
Just replace them with the OEM ones, you won't go wrong.
