e30 325i converting automatic to manual
Cameron
Hi Guys,
I recently converted my auto 325i to manual, but i am having problems with the starter, i replaced it twice but it is still breaking, but the housing seems to breaking at the nose of the starter, and when the car is started it gives a whipping start. Guys could you advise me on what could be the problem please?
Simply_Me
You might need a reduction starter. What year model is your car? Did you move the CPS to the front or did you keep it on the bellhousing?
I also made my car manual about 2ish years back. PM me
Cameron
The starter never gave problems before and it has been replaced.
the car is a 88 model, i kept it on the bellhousing
No the starter never gave problems before and i replaced it with a new 1 but that broke again
Simply_Me
Plastic bumper 325i with CPS on the bellhousing?... Doesn't sound right. Are you 100% sure?
Did you replace the flywheel when converting? Did you check the condition of the pilot bearing and the flywheel ring gear?
When you replaced the starter did you put in a chrome bumper starter or reduction starter? Is the clutch release fork the correct width?
Check this out and go through each step correctly, the auto/manual conversion can go very wrong very quickly
http://www.e30clubsa.co.za/forum/in...ion-auto-4hp22-to-manual-getrag-260-e30-325i/
