e30 2door with 733i motor
branlyn
Hi guys i put a 733i motor into a e30 2door,just wanted to find out if anyone has done this mod before need some info.
branlyn
635_wes said:
1) Welcome:thumbs:
2) :ttiuwp:
3) What info are you looking for?
need to know what radiator i can use the hoses i can make a plan with,cause i have fitted the engine already need to cut the front to fitt in radiator
Nic_s
Well... it'll have the same motor, but without all the Alpina bits. Personally I would have gone with the 3.5L motor. Still a nice build and can't wait for the picks.
branlyn
Rooi_Willie said:
Would this mod then give you a 333i ?:fencelook:
Basically yes without the alpina bits,but i made new mountings and fitts well just needed to cut the front to fitt in radiator.i got the motor for 1000rand from a old couple who wanted to get rid of 733i as scrap.I have a friend who done the 335 runs well.will post pics soon.
MikeR
:thumbs:
which e30 is the doner ? you going to have loads of work to beef it up, how is the suspension on the e30 looking.
same Motor ! as 333
Fordkoppie
Put da radiator in front of grille no cutting required problem solved celebrate by spinning :rollsmile:
Or if you want to do it properly, you can try source a real 333 radiator or even have one made up to fit under the cradle where the AC condenser was previously mounted.
Wes
branlyn said:
635_wes said:
1) Welcome:thumbs:
2) :ttiuwp:
Speak to a company like Silverton Radiators, they would be able to assist with getting the exact size you require.:thumbs:
branlyn
MikeR said:
:thumbs:
same Motor ! as 333
yes it is lucky the guy i got the shell from had done wheel bearings,ball joints and controll arm bushes only thing is to lower the suspension,interior(dash board)its beefed up already,head was done by van de linde developments complete exhaust system 63mm twin pipe and management system so very keen to see what power its going to make
Dbecks07 said:
Welcome - would love a pic of the bay...
will do that
branlyn
Managed to get silverton radiators to make up a radiator for me had to use e36 core and the e28 528i tanks
kugs330
:thumbs: welcome good luck with your build. Will a 2007 650ci fit in an e30 engine bay because ive got the engine gearbox and diff and dont know what to put it in :fencelook:
P
Psymon69
any engine can fit in any car, just depends on budget:rollsmile:
branlyn
I dont know but i can tell you alot of modifications.would be a nice build though.the biggest problem is to fitt the radiator.the space is tight thats why i cut the front of mine.
