Boosted@TheFanatics said:
Have you had your wheel alignment checked out? The wheel speed sensor checks for the steering angle, if there's an issue, it will throw the error where it tells you that DTC is disabled etc ...
Thanks for the reply guys.
It only started after I did waterpump and painted calipers. I have gone through all the sensors and inspected them and cleaned them.
I had a bunch of codes pop up at first;
5DE1
DSC: Brake-pad wear: plausibility, rear axle
Error will not cause a warning light
Error is not currently present
Test conditions have been completed
5DE0
DSC: Brake-pad wear: plausibility, front axle
5DA3
DSC: Wheel-speed sensor: plausibility, front right
Error will cause a warning light
5D93
DSC: Wheel-speed sensor, plausibility, front left
5DB2
DSC: Wheel-speed sensor: increment gear, rear left
After clearing those I still have one code popping up, so removing the shaft this weekend to inspect the ABS ring.
5DB2
