DSC issue
M3_e36
Yo peeps
had a strange one happen last night while i was driving my DSC turned off automatically(light stayed on) tried but couldnt turn it off. Got home turned the car off and switched on again and was working fine, today it seems fine again just last night it done it for the 1st time, Is there anything i need to worry about or look to start replacing? I dont mind no traction i'll rather let it break and stay off than stay on thou :rollsmile:
applehero
Its most likely a wheel speed sensor that has a bad connection. Have the codes read - this will tell you alot more.
OppositeLockMT
Interesting. I've had no DSC for the past 4 months because of a faulty wheel speed sensor, granted the tail will only step out of line when the ground is slippery.
wheel sensors or steering angle sensor...
my wheel sensors were dirty... i cleaned them and it went away :)
also if you running odd tire sizes it may make the car more sensitive to tire pressure...
