As far as i know, since the E46 BMW introduced DTC and DSC. While they might appear to be one in the same, theyre actually not. You get to activate and deactivate them using the same DSC button. When DSC button is pressed in for a second or two, you deactivate the DTC. Dynamic Traction Control, you will see a yellow DTC light on you dash. Which in turn allows for wheel spinning. Which also helps for fast pulloffs, that way the car doesnt bog down. Yet take a corner to wildly and the DSC will still kick in. Ie:no drifting. Now press and hold the DSC in for 5 odd seconds, and everything turns off. You will see a circle now on your dash with DSC that lights up. Now the Dynamic Stability Control is off. This in turn allows for wheel spinning and drifting. But be careful, there will be NO driver aids switched on at this time!
