Double Vanos seals info
These cars have Double Vanos
BMW 6-cylinder engines M52TU, M54, M56, 1998-2006
3-series E46 98-05, 5-series E39 99-03 / E60 & E61 02-05, 7-series E38 98-01 / E65 & E66 02-05, Z3 E36 98-02, Z4 E85 02-05, X3 E83 03-06, X5 E53 00-06
Double vanos seals are easy to change and dont require also to special tools :rollsmile:
I would still print this DIY and give it to your mechanic (if you dont want to DIY) so he knows the correct way to do this and you know you getting the best job possible :)
A new valve cover gasket will need to be fitted if it has not been changed within the last 50 000km to avoid oil leaks this can be got at BMW or the workshop doing the work
here is the double vanos seal DIY look though it because it also suggests some other parts that should be looked at while you do this job :)
If you want more info on how the seals affect your car and why they fail CLICK
currently not available for M cars :( sorry... my supplier is working on M3 seals that should be out soon... currently no seals are available for the V8 but it seems they in the pipeline also can probably expect them after the M3 seals...
current batch of vanos seals is going for:
R750
Free shipping to major centers and free post to outlaying areas :)
frikkieh said:
My favourite DIY. The best job I ever did to my car.
so it did improve performance and fuel consumption? how was the DIY...
im sure people looking at doing this would like to know your experience with it :rollsmile:
Pho3niX90
Hey man, hope you are still selling this, I want to do my vanos, I have the 330i E46 2005, what will the seals cost me to do the vanos? It seems like the car is struggling in lower rpm's, sometimes shakes, also, when car is started the is a horrible sound coming from engine, but not always, maybe vanos ratteling? . I also want the rattle kit from you.
Diglennzo
R750
:tiptoe:
looking for E46 double vanos seals and rettle repair kit. how much can you charge me on both.
