S
S1NGH 001
Just curious to know, how many of you guys idle your tractors before switching them off after a drive ?
petrivanzyl said:I don't
SP33DYV said:petrivanzyl said:I don't
You don't have to, you drive too slow in any case.:fencelook:
Philip Foglar said:petrivanzyl said:I don't
LOL, but your car by default stops the engine at robots or stops - personally I would disable that feature every time I started a journey. Still remember at the F30 launch how these cars would come in and the engine would stop and then immediately start up again due to the way the people were moving them when parking after the test drive. :nonono:
The start/stop thing makes sense on a petrol car anyway, not really so much on a diesel since they can idle all day long on a sniff of diesel whereas a petrol will eat fuel while sitting...
Philip Foglar said:With any turbo engine I would allow it to idle a bit before shutting off, but most important is to do a "cool off" run as you are nearing your destination - nothing better than off throttle running under compression or just light throttle. The turbo is then working far less and is able to cool off far easier than even idling - reason being, when the car is now sitting idling there is then no airflow through the engine bay and the electric fan only comes on for the sake of coolant and engine temperature - so no point idling the engine if you have just been giving it horns!
flyhid said:I thought that all newer model turbo cars has has turbo protectors so no need to idle or am I wrong.......
S1NGH 001 said:We're a bunch of clued up fanatics :rollsmile:
It's always advisable to let the Turbo cool down for a bit, especially when driving hard, remember the turbo is running at approx 19000 - 22000 rpm
Dippies said:I always let it run for at least two min after any Trip before i Switch it off.
Especially after hard Boosting and Spirited Driving.
Old advice from the days of belt-driven water pumps.
Electric water pumps have made this a non-issue. The pump continues to run after the car is turned off, and cools down the turbo
