tumzozo said:Hi Fanatics,
Is there any place where I can source diagnostic tool cables for the E36 and E90 locally?
Ratslaaf said:No one uses serial ports anymore, it's more convenient using a USB interface.
In other news, I've figured out the issue with the Zasstra cables and as I suspected, it's the USB to Serial chips. These are clones instead of the proper FTDI chips.
So, it looks like we can buy the Zasstra cables and just replace these chips. I'll order a bunch of these in order to help the guys out here.
tumzozo said:unfortunately I don't have a laptop with a serial adapter Akajee...
I never knew about Electroman I will definitely check them out.
T:ty:
///Moose said:Carsoft on electroman goes for R1599
akajee said:tumzozo said:unfortunately I don't have a laptop with a serial adapter Akajee...
T:ty:
You can get one for about R200 at max...
German_spec said:Ratslaaf said:No one uses serial ports anymore, it's more convenient using a USB interface.
Ratslaaf, what do these chips cost?
Ratslaaf said:German_spec said:Ratslaaf said:No one uses serial ports anymore, it's more convenient using a USB interface.
About R80 excl. But I've replaced it and now have the serial port working properly. I see now there's an issue with the software running on the cable as well. I've upgraded the firmware on the AVR chip, just waiting for my PLD programmer to come back so I can upgrade that firmware as well. I've checked the hardware and it's pretty much identical to the expensive cable I've got here.
