Diagnose This!!!
Hey
If i pull off and accelerate hard my car moves like it should.........I then change to 2nd and continue accelerating hard and all is fine.....I then change to 3rd and accelerate hard and revs stay at about 4000rpm and you can hear the engine revving up but the car goes nowhere.....same with 4th and 5th.......It basically feels like the back wheels are just spinning. Hope that makes sense.....
(Mcoupe/S54)
Any Ideas what it could be?
Thanks guys
Heinrich
if it's a manual, it sounds like a clutch.
once had a clutch that still lets me spin the wheels in 1st and 2nd gear but starts slipping in high gears
andrewbuch
Sounds like clutch.. had similar on our Pajero 2.5 TD.. 1st & 2nd & 3rd was fine but when in 4th the revs climbed & speed did not
when going though the gears hard like that and the clutch is slipping slightly it can overheat and not bite...
it could also be the hydrophilic fluid/pipes
Hey guys
Once again, thanks for all your help guys :ty: You guys were spot on...
Its the clutch on its way out.......Looking to set me back +- 14k :thumbdo:
Anyway thanks again.......
Now to get the vaseline ready
L8r
Sankekur said:
I am assuming that price is from the dealers? Can't you get it elsewhere?
Hey Sankekur
Correct, that would be from the stealers. Mech told me that when he previously had to fit one on another vehicle, he tried another make but it didn't work as some of the holes on the flywheel didn't line up and crap like that.
Will get an exact quote later today from stealers and then take it from there.
Or if you guys know of where i could possibly try other than the stealers, then please point me in the right direction.
L8r
zaleonardz@DentDoctor said:
yar dude, thats ky territory...
Hey Doc
You right.....I can already see them asking me to open wide.................:cry:
Will get exact quote later and then take it from there.
L8r
Sankekur
ahmed e bhamjee said:
Hey Sankekur
L8r
Well the flywheel and clutch should be LUK or sachs, not sure, so at least go to a clutch shop that sells these brands and hear if they can get it, I would try my best not to buy something like this from the dealers.
For my car clutch kit from the dealers - R5k, from a clutch shop - around R2.3k.
Hey Sankekur
L8r
Thanks Sank
Will definitely try that first before spending some well earned money @the stealers. Hopefully someone would have it. Do i also have to change the flywheel??
