Introducing GlossWorx
Towards the end of last year we were given a sample of products to test out. My initial impression was fairly high. Good quality packaging and a decent core range of products. The proof of pudding however is in the eating. We put the products through its paces and they passed our tests with flying colours. It therefore gives me great pleasure in introducing the Glossworx range. We’ve put together absolutely awesome deals on the new range to cover your every requirement. GlossWorx brings you quality at the most affordable prices.
R153
Glossworx Streak Free, Tint Safe Window Cleaner. Quite possibly the best cleaning liquid ever. Streak Free Cleaner sprays like water. No foam & no harsh smell. Just wipe and watch dirt, grease, water spots, smudges and just about anything disappear. Clean windows improve visibility. Streak-Free is tint safe for your windows.
No streaks ever!
GlossWorx Speed Detailer is a carnuaba enhanced spray and detail gloss enhancer. Restores a deep wet look shine in seconds. This detailer has a variety of uses too.Use between washes and wax applications. Can be used on glass, chrome and fibre-glass and it can be used as a clay lubricant.
The fastest easiest way to shine your car with a wet look finish in seconds. The wet look comes from a polymer resin based fluid combined with acrylic wetting agents and lubricants. No streaking and no effort on all paint surface
And get a 500ml bottle of GlossWorx - Shampoo absolutely FREE!
GlossWorx Shampoo is a strong cleaning shampoo that offers outstanding cleaning results through a consistent release of light foam. It uses uniquely formulated foaming technology and works with the suspension of super polymers within each bubble allowing grime and built up dirt to be easily washed away. The lubricity loosens abrasive residue and allows it to be rinsed away without scratching the surface. This unique formulation retains lubricity and will not allow water to remain on the surface hence causing calcium deposit and water spots.
R153
Glossworx - Leather Conditioner 500ml
GlossWorx leather conditioner leaves a silky smooth dry to the touch feel while restoring a fresh natural leather smell. Glossworx dry to the touch forumla beautifies, cleans, conditions and preserves the strength of old and new leather.
Glossworx - Silky Shine Dressing 500ml
GlossWorx Silky Shine Dressing is designed for both exterior and interior surfaces of vehicles, trucks, RV's and boats. This formula is silicone rich and contains special ingredients that ensures leather penetration as well as vinyl, plastic and rubber surfaces. This results in maximum protection and a long lasting. rich gloss. The pleasant scent worked into this dressing heightens worker satisfaction with the performance and quality you expect from all Gloss Worx products.
And get a bottle of Glossworx - Shampoo 500ml absolutely free!
R180
Glossworx - Wheel & tyre cleaner 500ml
GlossWorx Wheel and Tyre Cleaner is ideal for all wheels. Increased time in contact with the wheel allows the cleaner to continuously break down grime and brake dust. Spray it on your wheels and your can just rinse away the loose contaminants.
For more stubborn dirt, agitate with a soft cloth, sponge or brush. Test compatibility with a small area of wheel first.
Dissolves grease without the risk of damaging the wheel. Highly effective wheel cleaner that safely removes brake dust, oxidisation oil and dirt without brushing. Unique non Hydrofluoric Acid formula makes painted wheels shine like new. Spray-on, wipe off, no scrubbing necessary. No harsh scent. Perfect for pressure washing and parts cleaning.
Glossworx - Extreme Tyre Shine 500ml
Gloss Worx Extreme Tyre Shine, solvent based dressing utilizes high viscosity solvents to produce a rich long lasting high gloss shine on rubber, trim, plastic and vinyl surfaces. High defination shine, super glossy premium solvent based dressing, not water soluble. The wettest looking shine available for tyres, mouldings, bumpers, plastic, interior and exterior surfaces.
R153
No streaks ever!
R153
R180
