Crank no start issue
eddieger88
So i have a 2000 323i with a crank no start issue.I have replaced the fuel pump filter ,changed all spark plugs and fuel injectors,changed oil and oil filter,and cam and crankshaft position sensors.I checked and tested all the fuses and relays and the fuel pump is definately priming up.Also i made sure it wasnt cuz of a bad key.Ive pretty much got it pegged as a fuel issue but my next step i guess would be a compression test??Any advice would be great thanks
Sent from my LM-X410(FG) using Tapatalk
