MR_Y said:Hi,
Just wondering why BMWs of late have ditched coolant temp gauges for oil temp guages instead?
Surely having a coolant guage is better?
Sheldon13 said:My thought is the cars not having a temp gauge is because of the regulating temperature for fuel economy.
Temperature can vary from 115C to 87C depending on load.
Imagine looking at your heat gauge going up down everytime you floor it.
Just my 2cents
Not sure if i am right
yush1 said:I also like the coolant gauge. Im happy the F30 has it. Missed it on the E90. It just gives you comfort. :smilebounce:
yush1 said:That is the oil temp gauge (look at the little oil tin can picture in the gauge).
I never noticed that. Thanks :thumbs:
MR_Y said:Sheldon13 said:My thought is the cars not having a temp gauge is because of the regulating temperature for fuel economy.
Just my 2cents
Regarding coolant temperature, Niccol Louw from Car Mag did a podcast with 702 a few months back.
Cars with coolant temp gauge have "hysteresis" built into the guage.
This means that short-term erratic fluctuations are ignored (needle stays fixed), but only sustained/long-term swings are shown.
Hysteresis can be a dynamic lag between an input and an output that disappears if the input is varied more slowly
My point is that everyday people care more about coolant temp, rather than oil temp.
Older (non M) BMWs have coolant gauges, not oil temp gauges.
You cannot rely on oil temp to tell you how hot your coolant is.
In a diesel car, I appreciate that an oil temp gauge has some value, given that you need the oil temp to be at optimum temp before you can start using the performance. For everyday petrol cars, this is not a real issue (unless, you have an M Car).
S1NGH 911 said:MR_Y said:Sheldon13 said:My thought is the cars not having a temp gauge is because of the regulating temperature for fuel economy.
Just my 2cents
It takes less than a minute to view the coolant temp via the hidden obc menu
S1NGH 911 said:It takes less than a minute to view the coolant temp via the hidden obc menu![]()
