MAreff said:
Hi guys. i'm new to this so excuse the ignorance.
I own a 2000 318i manual. First beemer.
i'm experiencing a constant vibration on my steering from 80km upwards. When i go on uneven roads or bumps, theres a rattling noise in my steering column. my front wheels feel a little wobbly as well. I've been to 3 or 4 mechs and each one has a different diagnosis. One mech says it's the steering rack, the other says it's my control arms and bushes.
i've replaced the lower control arm bushes and the rack ends and i still experience the same problem. the latest diagnosis i got was yesterday: The mech says it "COULD" be the steering spindle upper and lower thats causing the noise in the column. The stealers want R 3700 for the parts. Thats crazy. Please can anyone assist or put in contact with someone that can assist...
Are your mags/wheels ok (i.e not buckled) and did you check your balancing. Also, after replacing the lower control arm bushes, did you redo your alignment.
StK said:
Legacy said:
If some of you still haven't figured out how many there are it basically works like this on the E46:
Part No2 is the anti-roll bar bushes
If part No2 are worn then you can experience vibration at speed,rubbing when turning the wheel,odd sensation when brakeing,knocking...Opinion is varied on whether to replace these with OEM or with powerflex...many say that powerflex don't work as well on the control arms as OEM ones however I have not had a problem with powerflex...also powerflex are stiffer so you get a more direct feel when steering
I'm thinking of replacing my anti roll bar bushes. I'm experiencing some of the symptoms (but very slightly and at high speed only :mmm: ) and think it might be good preventative maintenance in any case.
NB: I had the normal control arm bushes (Part 1) replaced recently, and they were quite badly f&*(Ked when it was pulled out. Hence, I'm thinking of doing the roll bar ones as new bushes should sharpen up the handling a bit too.
Anyway, BMW wants R205 each. Is there anyone else in Gauteng that also stocks these? I think I have the 24mm ones, but will jack up the car on the weekend to verify size.
