Clutch problems e36 328i
slotcars1
Hi everybody
So yesterday, I was heading down the road in 2nd, tried to get 3rd but the clutch pedal stuck at the floor. Pulled to the side and couldnt get any gears after pulling the clutch pedal... eventually get it into gear and coast home in 1st but the clutch is now shuddering and slipping like hectic.
Took it to the mechanic this morning and he says probably the hydraulics... any ideas from you guys?
Anarchy05
Our hilux did the same,master clutch cylinder was screwed,leaking,just got the seals replaced and voila- perfect.
328ii
slotcars1 said:
Hi everybody
The brakes and clutch work from the same hydraulic system.
If the brakes are still fine then it is probably a mechanical part in clutch
Remove the clutch slave cylinder and see if the push rod is not broken.
8?>
Anarchy05
Difference is that bakkie we had from new,2005,and we went through 2 clutches,3 thrustbearings and 2 seal replacements.Had to be karma or something.150k km we sold it
Phoenix
It's either the master or slave clutch cylinder......more than likely the seals. Might be worth doing the seals on both while you're at it?
