sobhiomar39
i have an e36 1992 with m52b28 engine swaped on it
since swapping the engine i realized that the engagement of clutch is lower than usual which makes the gears are very stiff
my mechanical said that the sleeve cylinder is bad and its the reason
so we changed it but after bleeding the car dont accept any gears
so we change the master cylinder behind the pedal
and it works fine until the next day i found that the car doesn't accept any gears again
the mechanical said that there are no air in the lines
so what may cause something like that??
Sent from my CPH1937 using Tapatalk
