Checked all fuses
GPGrobler
Hallo all,
I checked all the fuses on the E46, all are fine. The following things on the car are not working:
The horn, the steering wheel controls, the wipers. Are there modules controlling these things, if so, which one and where is it located? Also, anyone know how I set the clock on the car and where is the clock? Does the radio have a clock or clock display? Which aftermarket ICE unit can I put in the car that would not look like it is coming from a cereal box, and that will also work with the steering wheel controls?
Are the wipers controlled by a special module, or is it just a relay setup with the 555 chip + timer for the intermittent settings?
Apologies for the long post, but my car is not roadworthy if the horn and the wipers are not working/working properly.
Thanks in advance.
