Check Engine light not working
johanmarais
Hi
So I tried to the the stomp test yesterday and could not get it right.
I eventually had the stopwatch out to make sure I did the 5 stomps in 5 second ..... but still could not get it going.
I went back to google and apparently the light should show briefly when you turn the ignition key and mine did not.
Next I removed the cluster just to find that there is no light or even a fitting in that slot :RedNo:..... ok, remember I purchased the car a week ago and you can imagine what I'm thinking.
Anyway, I took the parking brake light and put it in the empty slot and still no go.
Is there anyway, other than to change the cluster, to maybe add a test light or test the wiring?
bmw69
As far as i know the stomp test is for the US e34 cars only and our engine lights do not work.
My 1993 e34 525i engine light doesn't work either.
bmw69
Would need to have the car connected to software like INPA for diagnostics.
There is a 20 pin plug in the engine bay that is used to connect to the software and i believe the e34 cars need an ADS interface to work with INPA.
Carsoft is another one that works on the e34, can search Ebay for it.
Here are some links to the Diagnostic connectors
http://www.ebay.com/itm/BMW-ADS-Int...121610?hash=item280e732f4a:g:yQAAAOSwhcJWLpr7
http://www.ebay.com/itm/Interface-6...hash=item1e88944b4e:m:mNvQZMZLkIaGqh8Jlq0SvCw
