Can I do a DE-Cat?
Jarv
Hi Guys.
I want to know can i do a de-cat on my 2005 116i?
Im not sure where the 02 sensor sits,but if im not mistaken if a 02 senson sits infront of the CAT , can it be cut out without any engine light coming on?
Cause i know from my ex Fiesta ST , the 02 sensor sat behind the CAT.
Jarryd
GoCart
If your sensor is pre-cat (between you combustion chamber and catalytic convertor), there should be no reason for concern… because it measures before the cats you want to delete…
Send your VIN number (last 7 digests), I’ll check REAL OEM for layout and try to assist.
3V0M-WP
BMW Car Club Member
U need to disable the O2 sensors otherwise you gonna have a flat spot like I did.
By disabling,... meaning that you must "switch off / disconnect / disable" the O2 sensors in the OEM software.
No physical unplugging of the sensors
Sent from my GT-I9300 using Tapatalk 4
D
Dippies
Any tuner on the forum should be able to assist you in this regard please see the advartising section
Rommies
or you can put in a catfooler if you don't want to fork out the money on software :=):
its about R200-350 bucks
3V0M-WP
BMW Car Club Member
Pleasure Jarv.
There's no sw update to be done, just 1 "tweek" to disable the O2 sensors.
Catfoolers are a lot more
Jarv
Ok great.
Ok now to get technical, can I ask pf to cut out the cat and then they will install a mini cat fooler thingy and so the engine lights shouldnt come on?
