Buying a jb4 secondhand
t0by_o7
@pump_upp - best crypto pumps on telegram !
Hi, is there anything to look out for whem buying a jb4 secondhand?
335i n54
Thanks in advance
Twinz
Forum - Support
It is definitely not advisable to buy (used) tunes. But there are some good ones being sold on this forum sometimes.
The problem with Jb4 piggybacks especially N54/N55 is that they get modified to suit the purposes of the owner...such as adding or splicing for the use of meth/NLS/Antilag/speed defeat etc. Some of these Jbs become badly hacked.
Ask the seller to provide detailed pix especially of the plugs and the inside of the board. That will give you some indication of at least the quality.
///Avi
Just make sure you take the JB4 back to its standard settings. For example if the guy had a back end flash on his, you will need to swop from 4/3 to 4/2 when you install yours.
Also the setup could be totally different on his car for example single turbo. So you need to update to the latest correct firmware for your setup.
Edit: What Twinz said
boost3d
Where are you based? I am selling my jb4 n54 unit and can include fitment if you are in the JHB area...
I have the following
Jb4 N54
Anti Lag & Updated Processor ( brand new)
Data Cable
Jb4 Rev3 bluetooth unit
Yuben
Senior Moderator
Jb4 N54
Data Cable
This would be a good buy from a reputed member:thumbs::thumbs::thumbs:
t0by_o7
Jb4 N54
Data Cable
I am based in Port Elizabeth. What is the price?
boost3d
jb4 and data cable R4800
Jb4 without the data cable but Bluetooth rev3 R6500
Data cable with micro USB otg connector R400
Bluetooth rev3 on its own R2000
Brand new Anti lag kit & Brand new Jb4 chipset Processor R750 ( both parts are unfitted) the processor has been updated for those guys wanting to run port injection/anti lag etc
Or you can take everything for R7k and i will include postnet to postnet shipping..i see you are based in p.e so unfortunately i cant assist to install it for you
boost3d
Thank you to the OP for this post... I have subsequently managed to sell my jb4 and ancillaries :smilebounce:
