Ralf*
Derrick125 said:I hit something on the road yesterday, both front and rear driver side now have a large and smaller bubble respectively on the side wall.
Why do you'll say both need to be replaced on the rear if only one is damaged?
By the same reasoning is it necessary for me to replace all four of them?
Thanks,
Derrick
are your front and rear tyres different sizes ?
otherwise you could use the two good tyres from the left side and utilize them on either the front or the rear,
If they are different (narrow and wide), then the "norm" is to always replace tyres as a set...either both front or both rear, this is normally true if the wear on your existing tyres is such that it will make a significant difference to the rolling diameter of the used vs the new tyre.
Another bigger concern, is that if you hit something "THAT HARD" to cause an RFT to bubble, it might be worth to also have the suspension (shock mountings etc) and the mags inspected for damage, not quickly vizible
