Heven said:Anti Squeal compound on the caliper, between the tabs on the pads and caliper.
Heven said:Is copper grease the same as red grease?
Z3Zack said:Thanx you! I also need to do this. Has been squealing ever since installed new brake pads...
Dont have a pic, but if you remove the pads, you put it on the rear of the pad, the part that sits against the caliper.Lindo said:Can anyone post a picture on where exactly the copper grease should be applied :fencelook:
