Brake service lights going mental.
Nick
Hay gents!
I need to pick your brains a little bit.
My car had brakes changed before i took delivery, the dudes didnt reset the service lights on the brakes.
I tried today and now the will not reset.
same problem as this poor soul.
[video=youtube]
Any ideas how to fix it?
Midas335i
You have to fit a new wear sensor then reset it. The sensor wears with the brake pads, so they have to be replaced then reset the indicator.
Lots of guys don't change the sensor, one for the front and one for the rear :thumbs:
Nick
I could kiss you sir!!!:praise:
THANK YOU!
I can drive the car till Saturday yes?
KarshS
Had the same issue
One of the front sensor cable was rubbing against the rim and got cut with wear
The dealer just replced pads and dint put yhe cable right
Replaced it and all is good
Nick
need to check them today.
Took my dads e90 to work today to do a oil change...Get to the sumo plug and it just turns.
I think its stripped inside and will not come out.
Fun and games.
Nick
Car is fixed... the new sensors worked like a charm.
Thanx for the insight gents :praise:
