akash said:
Did you put in new brake sensors?
Ok just saw you did.
1 turn car on without starting
2 press and hold the trip reset button at the odometer, it will show a triangle and then go into the service reset
3 Use the toggle of the indicator stork to select the rear brake reset
4 Press and hold to reset the rear brake service light.
5 switch car off and the light should go out
I hope i go these steps right, doing it from memory. But there must be a post on the forum.
