gavsadler
So, the 130i is showing that it needs a brake fluid change.
Previously it was done at the dealer under motorplan. Now that I'm out of plan, I'm investigating options.
I've read a variety of posts, and some mention that you need to activate the ABS pump using the diagnostic software in order to bleed the old fluid out of it properly. Does anyone know if this is true for BMW as well?
I also read some stories where apparently they only suck out what they can out of the reservoir, and then top it up with clean fluid, lol.
Thoughts?
Thoughts?
