Brake disks and Pads??
Bak-Gat
Hi guys, please advise what brake disk and pads can I use for my F30 320D m-sport 2014??? , instead of the BMW one's that so expensive...
lebofa
Welcome to the forum bro. Have you tried to contact BMW Midrand? Speak to Diego and tell him you are from this forum. He will give you a good price. I have used non OEM brake pads and all of those that I have used squeaked very bad. I ended up going back to OEM and never had to worry about noisy brakes. As for the disks, you can use non OEM but my advice is to get a quotation from Diego and compare. BTW, stick to OEM and pay that extra few R100s for peace of mind . I still have brand new pairs of Deselra and Brembo that you can choose from if you are in JHB and interested to test. Both fronts and will let go of them for R300, my mobile number is 0835433402
Besides squeaking, these non OEM pads make a slight knocking sound when you reverse and brake.
PaulWW
I have just replaced my F30 320d's rear discs, pads & sensor at SupaQuick, having done the same on the front about 50K km ago. They used ATE pads, not sure of disc brand. Very happy with the outcome.
AshG108
You driving an F30 BMW and looking for a cheaer option than OEM but you can get a good discount from ABM on OEM which in many cases will be almost the same of cheaper than aftermarket.
I have tried aftermarket on 2 of my 3 BMWs and always, the OEM option worked best, especially in terms of noise, squeaking, screeching and performance in terms of break fade etc.
I say, give ABM a shot, compare and even if a few R100 extra...maybe try still keep it OEM.
