Howsit gents,
About two weeks ago on a friday i was on my way from work when i felt my car holding back, so i pulled off to check, couldnt find anything wrong, so drove to a safe place 2kms down the H'way on the N1 at the shell and saw some smoke come of the left front tire, the brakes seemed to have "melted"
I couldnt even touch the rim, it was flippen hot, so i jacked the car up...and the disk seemed not to move, so with a long screw driver i managed to release the pads apart from the disk, upon pressing the brake the calliper refused to move to make contact with the disk once again, so i figured i take it easy to get home and sort out there.
Upon removing the calliper, i couldnt get the piston pushed back, thats when i figured its siezed, tried clamps, hammering excessively but nothing doing, the other side seemed to brake fine. anyways after some phone calls i struggled to get a brake service kit so purchased a 2nd calliper from bemows, i fit it on, all seemed ok. When i decided to bleed the system i noticed the other side(that was working fine) has now siezed as well.....WTF!
Has any1 experienced this problem on an E36?? Please can i be offered some advice??
Apreciated!
Apreciated!
