BMW Mobility kit
Snip3r
Have you ever used the mobility kit and does it work? I've heard rumors that it doesn't work well and the goo melts under extreme heat, please advice.
KidB
Good question, I just assumed it will work. I also have a tyre repair kit and the goo in a can as extra insurance.
Sent from my D5803 using Tapatalk
cOlDFuSiOn
I had no choice but to drive 550km from northern cape to JHB on a stuffed run flat earlier this year, the tyre had developed a tear... I filled the left rear tyre with ONE can of foam when I left and proceeded to drive back.. I did normal causing speeds of 120ish, tyre made it back, low pressure warning only came on again about 20kms from home, but was ruined when I arrived. All good it got me home and served its purpose.
I have not used the mobility kit with the integrated foam I prefer the cans. In an emergency this is all you want, you replace the tyres and go on, it is by no means a permanent fix. :coolShake:
