BMW M3 e90 battery register.
Revs
Hi,
Need to find some one who can do a battery registrar on my M. The steelers are a rip off.
Battery was drained for standing for to long. Did a battery test and all is good.
Revs
vjx said:
Not very difficultby using X431 tools. And no big difference. I can help in Sandton area.
Please pm me. I stay in Fourways's area. I sent it in for over night charge and will pic the battery up on Thursday. Tks
Kish2604
Administrator
It's a used battery and not a new one, why you want to register it?
Revs
After the posts on Torque Affair's article, I thought I'd shed some light on this subject.
This article was written in 2010, it goes without saying all "F-chassis" cars in BMWs current lineup also have the same battery technology. So pretty much every new model since the Bangle-butt E65 7-series.
The electrical system in late-model BMWs is so sophisticated that it tailors charging as closely as possible to both the type and age of the battery. There's a computer that controls the alternator. When you replace a battery, this computer really needs to know if you've replaced the battery or updated the vehicle from a conventional Lead Acid battery to an Absorbent Glass Mat (AGM) type; it charges the AGM differently than a traditional battery.
This process of updating the alternator-control computer is called Battery Registration. Ignoring the registration process after replacing a battery won't necessarily trigger a Diagnostic Trouble Code or Malfunction Indicator Lamp ('Check Engine' or 'Service Engine Soon' light). However, be warned that skipping the battery registration process can dramatically shorten the life of a battery in these vehicles and- worse yet- damage components within the entire electrical system.
Models that require battery registration:
2002 and newer 7-series E65/66 chassis
2003 and newer 6-series E63/54 chassis
2004 and newer 5-series E60/61 chassis
2006 and newer 3-series E90 E91 E92 AND E93 CHASSIS
2007 and newer X5 series E70 chassis
2008 and newer X6 series E71 chassis
This Service Function informs the vehicle that the battery has been replaced. It completes the following operations:
- Battery capacity is set to 80
- Current Odometer reading are stored. The odometer readings at which the last seven battery replacements took place
can be read off from the Diagnosis Requests of Control Unit Functions
- Stored battery statistics (current, voltage, battery charge level) are deleted
- Stored temperature statistics are deleted
Absorbent Glass Matt Battery or AGM
At the time this was written (6/2010) most European manufacturers use black case batteries to denote an AGM battery and white clear plastic battery cases denote Lead-Acid. U.S. made replacement batteries do not follow this protocol and case color is notan indicator of battery type.
In contrast to conventional lead-calcium batteries, the sulfuric acid in an AGM battery is not held freely in the battery housing. The sulfuric acid is instead entirely bound into the mats of the glass-fiber fleece. For this reason, no acid can escape if the battery housing is damaged. In addition, the AGM battery is a sealed, airtight unit. This is possible because the gasses are converted back into water by the permeability of the separators.
Construction
AGM batteries differ from conventional lead-calcium batteries in the following points:
- Larger plates which allow a power density some 25 greater
- Glass-fiber-fleece separators which enable a cycle consistency up to 3x greater improving cold-starting ability, current consumption and service life
- Airtight housing with pressure relief valve
- Inspection plugs sealed and cannot be opened
- Acid bound in glass-fiber fleece
How AGM Batteries Work
AGM batteries differ from conventional lead-calcium batteries in their environmental compatibility and their retention of gases during charging. When a vehicle battery is charged, the electrolysis process emits the gases oxygen and hydrogen. In a conventional lead-calcium battery, these two gases are released into the atmosphere. In an AGM battery, the two gases are converted back into water: The oxygen created at the positive electrode during charging moves through the permeable glass-fiber fleece to the negative electrode, where it reacts with the hydrogen ions that are brought in with the electrolyte, to create water (oxygen cycle). In this manner, the gases, and thus the electrolyte, is not lost. Only when the gas production is excessive, that is when too much pressure is generated (20 to 200 mbar), does the pressure-relief valve open, thereby allowing gas to escape while also preventing entry of atmospheric oxygen. Because the pressure in the battery is regulated by a valve, the AGM battery is also known as the VRLA battery (valve regulated lead acid).
Battery Replacement
An AGM battery, when installed as original equipment, must always be replaced with an AGM battery. In special cases, where a customer's driving profile (e.g. short distance driving), results in a discharged battery, the AGM battery is a recommended replacement.
Don't fret though, there are budget versions of the battery so you don't have to give all your money to the dealership. Duralast (Platinum H6-AGM) makes an AGM battery that is usually half the cost on the OEM BMW part.
Can you do it yourself?
There are many OBD-II programming tools on the market and a few have the capability to register batteries to the new cars. These programs are usually expensive although more options are coming to the market every day to make this problem easier to deal with.
Kish2604
Administrator
Great general knowledge post however my question was, if you are not replacing the battery then why do you want to register it? Or am I missing the boat on something here?
Revs
From what I found out and stand to be corrected is if the battery losses charge or continues to give you the yellow battery light and doesn't keep time or date then it needs to be "replaced" and registered. So in other words if you recharge the battery to it full capacity and reinstall it the obc needs to be reset. ( registered ) I have remove my battery and taken it to better center and the guys there are really helpful. They recharging my battery for R50 and will do test again. They did inform me that they supply Bmw agm batteries at R3200 and BMW is charging R 3700 excluding registration.
They didn't just jump in and say you battery is shot and needs to be replaced.
I read up some where that it can play havoc on the dct gearbox to if the voltage is not correct.
That what I understand from this whole event.
