Hi all,
I have some probs with the good old M, S50B32
it's a 95 m3 saloon, Smoking ...a lot. it's an oil issue.. blue/greyish smoke
On acceleration/ deceleration only when the engine is warm. On idle only smoking when warm and driven for a while. idles rough ish'
Recently done head gasket valve seals etc on that end.. for 200 kms it was fine and then it started smoking again...
Compression is 95% all round 6 cylinders .
Cyclone separator is open and no vacuum leaks as far as I know.
Oil sump is not original with the separate oil vent plenum.
So I modded the dipstick to have a crankcase vent system like a 328i
Could this be my problem ? oil consumption is quite bad as it's getting oil from somewhere.... spark plugs look a bit wet from oil but not a lot.[/size][/font]
